I wanted to know if someone here knows how evenly level volume in a track.
My issue is that I had to audio inputs with different volumes switching every 60sec.
I am attaching an example.
Envelope Tool is one solution …
As the music is repetitive, you could use repair channel plugin to patch-in a section at the transitions, if you’re having trouble hiding the join with envelope tool …
Its not a software issue, its the recording itself.
every 60sec the broadcasting software was switching between 2 video scenes with audio source that had different volumes in each scenes.
Robert J H wrote Nyquist code which chops alternately between channels.
Theoretically***** that code could split the track into loud on one channel & quiet on the other.
Then raise the volume on quiet channel to match the loud one (+10dB)…
[ ***** In practice it may not work if the timings are not exact ].
