How to compile Audacity 2.0.4 on Linux Mint
This post is (unofficial) detailed documentation of installing Audacity 2.0.4 on Linux Mint. Although written specifically for Linux Mint 15 Olivia (Mate edition with multi-media support, http://www.linuxmint.com/download.php), the following steps will probably work on Ubuntu and other Ubuntu derivatives.
IF YOU ENCOUNTER PROBLEMS BUILDING “AUDACITY 2.0.4”, PLEASE POST HERE:
http://forum.audacityteam.org/posting.php?mode=post&f=19
Building Audacity:
  1. Obtain the Audacity from Google Code: http://code.google.com/p/audacity/downloads/list?can=2&q=linux
  2. Open the downloaded file (double click on it) with “Archive Manager” and extract to your home directory.
  3. Enable ‘source’ URIs in your sources.list". Menu > Preferences > Software Sources > Source Code and enable source code repositories.
  4. Open a Terminal window and enter the following to install the necessary dependencies:
sudo apt-get build-dep audacity
Enter your password when prompted to do so.
When prompted “Do you want to continue [Y/n]?” type “y” and press “Enter”.
5. Change directory to where Audacity has been extracted, for example:
cd audacity-src-2.0.4
  1. Type the following command:
./configure
Wait while your system is checked and Audacity is configured.
Configure should complete with the following message:
Run 'configure --help' for an explanation of these options,
otherwise run 'make' to build Audacity.
If an error is shown, please copy the last 10 lines or so from the terminal window and post them here.
There is no point in continuing the installation if configure failed. Proceed to the next step only if ./configure completed successfully.
7. Type the following command:
make
Wait while Audacity is built. This can take a long time on slower machines.
There will probably be a lot of warnings shown in the output - that’s OK as long as there are no errors.
Make should complete with the following message:
1327 translated messages, 52 fuzzy translations, 931 untranslated messages.
msgfmt -v -o zh/audacity.mo zh.po
2314 translated messages.
msgfmt -v -o zh_TW/audacity.mo zh_TW.po
1991 translated messages, 27 fuzzy translations, 292 untranslated messages.
make[1]: Leaving directory `/home/user-name/audacity-src-2.0.4/locale'
cat help/audacity.1 | gzip -9 > help/audacity.1.gz
Testing the newly built Audacity:
While still in the source code directory in the Terminal, type the following command:
./audacity
Audacity should then launch.
You will see a lot of messages similar to below in the terminal window while Audacity examines the sound system, which is normal.
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround71
ALSA lib setup.c:565:(add_elem) Cannot obtain info for CTL elem (MIXER,'IEC958 Playback Default',0,0,0): No such file or directory
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
bt_audio_service_open: connect() failed: Connection refused (111)
ALSA lib pcm_dmix.c:957:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
Expression 'ret' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1670
Expression 'AlsaOpen( &alsaApi->baseHostApiRep, params, streamDir, &self->pcm )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1830
Expression 'PaAlsaStreamComponent_Initialize( &self->capture, alsaApi, inParams, StreamDirection_In, NULL != callback )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2092
Expression 'PaAlsaStream_Initialize( stream, alsaHostApi, inputParameters, outputParameters, sampleRate, framesPerBuffer, callback, streamFlags, userData )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2764
Expression 'stream->playback.pcm' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 4541
ALSA lib pcm_dsnoop.c:612:(snd_pcm_dsnoop_open) unable to open slave
You should now be able to use Audacity.
Note that the Audacity manual is not installed by default, but the on-line version is available via the Audacity Help menu.
If Audacity fails to run or function properly, please post details.
Recommended settings:
There are many customisations available in the Preferences section: “Edit menu > Preferences”. It is advised to keep most of these at their default settings until you are familiar with the program and fully understand what the settings will do. Full details of the Preference settings are available in the Audacity manual: http://manual.audacityteam.org/o/man/preferences.html
The following Preference settings are recommended:
  • “Edit > Preferences > Devices”: Unless you intend to use Jack Audio System, set the playback device to the ALSA hardware device - the name will end with something like (hw:0,0). Playback is generally more reliable when accessing the sound card directly through ALSA rather than the “default” setting which uses PulseAudio. If you wish to use other audio applications at the same time as Audacity then you will probably need to set the playback device to “default” or “pulse” so that PulseAudio can manage sharing of the sound card between applications. Audacity will usually run OK with PulseAudio, but may freeze occasionally when playback starts or stops.
    If Audacity freezes, it can be closed by pressing “Alt+F2” to open a command prompt, then enter:
killall audacity
  • For multi-track (overdub) recording, “Edit > Preferences > Recording: Latency” will need to be configured. See here for details: http://manual.audacityteam.org/o/man/latency_test.html
  • “Edit > Preferences > Quality”: Set “High quality conversion: Dither” to “Triangle”. This is recommended so as to avoid a known bug in the default “Shaped” dither.
Note: Due to a bug in WxWidgets 2.8.12, when Preferences are closed, the main Audacity menu may disappear. This applies when using Mate (Linux Mint) or Gnome Classic but (probably) not if using Cinnamon (Mint) or Unity (Ubuntu). To restore the menu, resize (or maximize/unmaximize) the Audacity window after closing Preferences.
Installing Audacity:
Once you have confirmed that Audacity is working correctly, type the following into the Terminal window to install:
sudo make install
After logging out and back in, Audacity should be available in the applications menu (the exact location may depend on which desktop environment is used. For Mate, Audacity appears in “Menu > Sound & Video”
