I want to change the tone of a sample, without making it sound like it was just pitched down. How would I go about doing this?
Something like this: http://www.youtube.com/watch?v=4eHmVjmHOZQ
Is there a plugin or do I just have to add multiple effects?
Thanks,
//DS
Some one will correct me, but that clip is just autotuned and then cut into the song. Autotune has settings where you can tell it how vicious to be with the correction. Normally you would use it to gently push the pitch of a voice into tune with the song, but you can also use it to force a voice from someone who has no singing ability at all. Those are mostly for effect, they don’t sound particularly musical.
I remember a clip from a YouTube performer who just let his voice slide around and Autotune shoved it into a song. It sounded freaky which was the intention.
https://forum.audacityteam.org/t/free-primitive-autotune-plugin-2006-vintage/32248/1
Here it is. Mystery Guitarman. All of his stuff is special effects and crazy-good editing.
http://www.youtube.com/user/MysteryGuitarMan
I think this was his first posting.
http://www.youtube.com/watch?v=MuU00Q3RhDg&list=TLi7r7CCdXXEUDulrwvqfIaiJ7c-b1ERCa
15 million hits.
I can’t find his Autotune clip. Sorry.
kozikowski:
Do you know how I would go about doing this? I have a really tough time with autotune plugins.
December 25, 2013, 11:52pm
6
I’d use different software. It is possible to do in Audacity, but without MIDI support each note would need to be created manually which would be an extremely long and tedious job.
Trebor
December 26, 2013, 4:30pm
7
Sounds like something done with a sequencer , Audacity does have one of those but it’s very primitive …
/uploads/default/original/2X/d/d1ec923c375fd458fdb977b6cc1e6c219262db57.mp3
If you are composing a tune you really need software other than Audacity , e.g. …
A music sequencer (or audio sequencer or simply sequencer) is a device or application software that can record, edit, or play back music, by handling note and performance information in several forms, typically CV/Gate, MIDI, or Open Sound Control, and possibly audio and automation data for digital audio workstations (DAWs) and plug-ins.[note 1]
The advent of Musical Instrument Digital Interface (MIDI) and the Atari ST home computer in the 1980s gave programmers the opportunity to design softwar...
