How to change pitch in waves (IDK how to describe it)
Audacity 2.0.5
Is there a way to make a clip fluctuate between high and low pitch (like a police siren does)?
Sorry about the vague description, I can’t think how to describe it better.
Effect > Change Pitch.
I think you’ll be doing it manually. Select the first segment > Change Pitch up. Select the second segment > Change Pitch down, etc.
