I like the “Light” theme, but I just think the background color is way too dark. I want to change it to #7D82A2. When I click “Custom” theme, nothing happens. I was expecting some color pickers? Is there a simple way to change the background to #7D82A2 without having to go through a complicated process of setting up an entire new theme?
The “Custom Theme” option allows you to select a custom theme. It does not help you to create one. Documentation for creating custom themes is here: https://audacity.gitbook.io/dev/scripting/creating-custom-themes
Thanks. There is no way I’m going to read all that and learn all those steps just so I can change 1 colour! I’ll leave it.
