I have around 100 wav voice recordings requiring amplification.
So far the only method that works is one-at-a-time, manually.
Inserting more that one wav into audacity, amplifying and then exporting as mp3s to the hd, instead saves one track with the overlapped recordings of the originals.
Is it possible to drag all 100 wavs into audacity, amplify them all and then automatically save/export the tracks individually as mp3s?
If not, is anyone aware of a software program that can do this?
instead of explicitly importing and export multiple you can also apply a Chain including Amplify to files ( Audacity Manual ). This has the advantage over Export Multiple that temporary disk space is released after processing each file, whereas you will need sufficient temporary space to import and amplify all 100 files if using Export Multiple.
