how to allign the dots??
Hi all,
first post here sorry if i missed somthing.
so i try to align the dots when you zoom in. but i cant seem to to it. can someone help me?
here is a link with a photo if i am confusing.
https://imgur.com/a/KtbpGGY
thank you in advance.
dear ragards.
You may have imported files with different sample rates.
The Project Rate is shown in the lower-left of the Audacity window and assuming you didn’t change it, it should match the 1st file opened/imported. (That will be the sample rate for the exported file.)
The Tracks menu has a Resample option so you can make them match.
Thabk you ill try tommorow and say if it works.
thank you man it worked love u
