I just installed v3.7.1 and am trying to configure it. In v3.3.3 I often used ACX check to check a segment’s peak and RMS levels. ACX check doesn’t come bundled with v3.7.1 so I found it, copied the file into Audacity’s nyquist and plug-in folders, and searched for it with Plugin manager. No luck. What to do? And if it is unavailable for v3.7.1, how can I check a recorded segment’s peak and RMS level?
