how do you normaize an audio file with audacity
hi
I just bought a new external sound card…its the presonus audiobox I two…how do you normalize a record file after you record it from your turntable with this external sound card?
lenny
The simplest way is to use the Amplify effect. It will scan your file and default for whatever gain is required for 0dB peaks. So if you want to normalize to 0dB peaks, run Amplify and accept the default.
…You do understand what normalizing does, right? It makes the peaks equal to preset level (usually “maximized” at 0dBFS). It does NOT match the perceived loudness to a preset level.
Be careful with noisy records. If there’s a loud vinyl “click” that’s louder than anything else, the click will determine the normalization level.
If you want to avoid that a single “extraordinary” peak will mess up your normalization level for the whole file, you may want to have a look at my DynAudNorm tool:
https://github.com/lordmulder/DynamicAudioNormalizer
