How do you do a slowing down audio that slides?
I use Windows XP and Windows 10 on separate computers. I use Audacity 2.0.6.
How do you do a slowing down audio pitch, that slides of where you can hear the audio slow down bit by bit in Audacity?
Here are some song examples:
https://www.youtube.com/watch?v=n8CQjcJbVCg (Listen at 5:24)
https://www.youtube.com/watch?v=iNngC1Ea2rA (Listen at 5:19)
What effect would you call that, because I called it slowing down audio pitch with slide?
Can Audacity do something like that?
Here is an example of the song speeding up bit by bit:
https://www.youtube.com/watch?v=wsF0UUs82MI (Listen at 6:36)
Speeding up audio pitch with slide.
I would like to be able to make the audio sound like that in Audacity.
“Turntable warp” plugin can do that, you can download a copy here …
http://wiki.audacityteam.org/wiki/Nyquist_Effect_Plug-ins#Turntable_Warping_MS
[ How to install plugin here … http://wiki.audacityteam.org/wiki/Download_Nyquist_Plug-ins#install ]
Alternatively, could use the built-in Audacity effect “Sliding Time Scale / Pitch Shift” which is similar.
Thanks. I found out that the effect was called Pitch Bender. I will try out the Record Warp effect and the Sliding Time Scale/Pitch Shift effect. Thank you so much.
