How do I record small sound bits of podcasts or youtube clip
Is it possible to record portions of clips from You Tube and Podcasts? Do I need to hook up a separate mic or can I do it somehow using the Audacity program? Please excuse my ignorance, just recently download the software and still stumbling a little. Thanks!
I am running Window 7 64 bit
You can do self-recording in Windows, but sometimes it can be a challenge. Some computers are actively hostile to the idea.
http://manual.audacityteam.org/o/man/tutorial_recording_audio_playing_on_the_computer.html
Thanks Koz, I’ll give it a try.
