Lemme know if I can isolate this for free somehow.
*I know this might be hard to do cause I know isolating even vocals is a really tough job but I’m just hoping someone on this forum can help me gate it so I can just get that scream .
It’s so embedded I can get the shells, management files, and html locators, but never the actual music. Also it’s got quite a number of filename violations in it. For universal filenames, never put punctuation marks in there, and if you transfer via ftp, spaces are a pain in the neck, too. You may be using Fetch or other FTP shell, but not everybody is.
If you put that file on a Windows machine it will cause a minor thermonuclear event.
I’ll be absolutely amazed if any one can isolate the “scream” noise.
My advice would be to get back with the ring modulator and make a new one - with any luck you’ll make something even better.
Are there any plugins similar to the Ringmodulator because I love the fact that you can control the wave pattern. It feels like you’re controlling a Moog synth hehe.
