Hi. I’ve used Audacity in the past with minimal problems. However, recently (and I don’t know why there was a change; I haven’t gone into any menus and changed anything and I haven’t added any new hardware - my only thought is that some other software update changed some internal audio parameters that affected Audacity somehow), when I record audio from YouTube, I get this kind of echo chamber sound – although the audio sounds fine on my PC, the Audacity recording acquires a kind of hollow sound. I’m using Audacity 2.1.1 on a Windows 10 PC. What settings do you recommend to get a more natural sound? The windows are too small so I can’t give you the full selection names that appear above the recording meter but these are the choices that I have set (from left to right): WINDOWS D // PRIMARY SOUND CA // 2 STEREO // PRIMARY SOUND DR.
Sounds like “Windows Enhancements”, (a Windows thing, not an Audacity thing). You should turn all “enhancements” off …
http://manual.audacityteam.org/man/faq_recording_troubleshooting.html#…sound_as_if_they_were_made_in_a_tunnel
Try selecting WASAPI loopback. See [u]this tutorial[/u].
You can drag Device Toolbar wider at its right-hand edge.
