I have set my output folder from the 2.0.2. version of audacity by my files in lame mp3 libary, my question or problem how can i find it back after. I installed the version of 2.0.4.?? thats a huge problem considerd that im a deejay
Greeting Mr melody86
The Lame software is in a folder inside the Audacity program folder. You should Save or Export your work to My Music or other working folder, not a program folder. An Audacity upgrade should not change the FFMpeg or Lame software, so your work should still be there. Search the machine for one of the music filenames and see if it hits.
