How do I enable job completion notifications?
So I’ve been using Audacity for a while (more specifically Paul’s De-Clicker plugin due to some crackling issues with my mic, but there is this annoying issue regarding some effects, where you can’t apply them to really long audios, or else they’ll fail, so I have to apply the effect in 10 minute chunks.
My issue is that I want to be efficient about it, and it’s a bit annoying having to check in the audacity window every 30 seconds or so to check if the effect is finished to start the next job, I’d like to know if there’s a way to have Audacity send a notification every time the effect finishes, whether via a native setting or through a plugin.
I tried the “Beep on completion of longer activities” setting, but it didn’t do anything. For added context, I use Audacity on Linux Mint Cinnamon 21.2.
