How do I create this vocal effect?
Hello there.
Included is a link to Fastball’s “The Way”
I think in the second verse there is the line: “They just walked off and left it all behind them.”
“Left it all behind them” is then repeated a little in the background and with effect; what I suspect is some Eq to give it that walkie-talkie/telephone quality and some sort of modulation.
If anyone could point me in the right direction as to how to recreate it I would be grateful.
Cheers
Grant
http://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=1&cad=rja&ved=0CDEQFjAA&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3Db0wfu3tOrtQ&ei=j9cSUtWrFIutiQfr1oCIAg&usg=AFQjCNETuS0fe_B1nmZHY_VCSEIDwbIW_g&sig2=XdJ8ib7v8XKJHrQWkp9_tw&bvm=bv.50768961,d.aGc
Can you give us a minute listing? Koz
