how do I create a 4 channel file for quad. sound in audacity
Hello,
I’ve been trying to create a four channel sound file for quadraphonic sound.
I read somewhere else that all one needed to do was to go to the Preferences menu and then to “File Formats” and to Advanced Mixing,
but I have not been able to find “File Formats” in the Preferences menu. Please advise,
Thank you,
Cheers!
The manual is probably the most reliable information.
"Edit > Preferences > Import / Export "
then un-check “Always mix all tracks down to stereo or mono channel(s)”
http://manual.audacityteam.org/o/man/import_export_preferences.html
