How do I combine two audio files?
Hi I am on Windows 7 and trying to import and combine 2 audio files…any clues on how to get this done (I am a complete pod cast novice!)
Can we assume play the second one after the first one is completed?
Import both tracks and Audacity will mount them one above the other and play them at once.
Select both (Shift-Click just above both MUTE buttons). Tracks > Align Tracks > End To End.
The tracks will play one after the other. When you Export, Audacity will make one single track out of that.
Great, thanks. I will try that and report back :slight_smile:
