Hi,
I am trying to use the AppendImport plugin. I have downloaded it and stored it in the plugin’s folder, and I have the latest version of Audacity 2.1.2. which was installed from the exe on the web site. I can’t see the AppendImport plugin anywhere in the Effect menu. I have clicked on Add / Remove Plug-ins… and can see that AppendImport is Enabled and that the directory path to it is correct.
As far as I can tell I have followed all the instructions correctly. Can anyone please spare a few moments to suggest what I am doing wrong or omitting?
I am running Windows 7. Thank you.
