How can I use Spectral editing to remove a seperate soundtrack from an audio file?
hello, I’m not sure if audacity can be used in this way, but i have a bunch of videos that got screwed up, like the video has two audio tracks playing at the same time, is there a way to remove one of them? Also, I’m not sure if i used the correct phrasing, but it’s as though there are two different frequencies, each playing their own audio track.
this is what I see:
https://i.imgur.com/vOjYvG0.png
https://i.imgur.com/QScUqqc.png
I’ve tried using the split audio function, however, it didn’t fix the issue.
It’s highly doubtful they can be separated, but if you want to post a sample of the audio, perhaps someone will take a look.
