Hi all!
How can I save text recognized by OpenVINO to a file?
You should be able to Export the Label track that it produces.
Use File > Export Other > Export Labels
Peter
I may be able to help here.
You can only export label text when the entire label track is selected. Clicking on the left side (below where the X to delete it is) will select it for you.
Thanks to all!
