How Can I remove the effect of character "F" from my voice?
Hello,
When I say the character “F” or “Ph” or “P” in front of a mic. The mouth blows some air into the mic. This air causes noise or distortion. Is audacity able to remove that noise? How can I do it?
Would you tell me some tips to prevent this issue from happening?
Thank you very much,
Pop shield … https://wikipedia.org/wiki/Pop_filter
