Highlight audio over a level
In my recording, I try to watch my audio levels and keep them in the -6 to -12db range. However, I tend to have the occasional spike of up to -3db.
Is there a way that I can either draw a horizontal line at -6db on my waveform so that I can see where those sections are and then individually normalize those sections?
Right now what I do is scroll through my recording and look for peaks that are well above the surrounding ranges.
Assuming that you have recorded in the default “32 bit float” format, the audio may be amplified up and down as often as you like with no loss of sound quality.
If you apply the Amplify effect with the default settings, it will amplify to a peak level of 0 dB. I expect it will then be easier to see the high peaks. Before exporting the finished track you may amplify (using either the Amplify or Normalize effects http://manual.audacityteam.org/o/man/amplify_and_normalize.html) to whatever peak level you want.
I increase the size of my sound meters so to better see what I’m doing.
http://kozco.com/tech/audacity/Audacity1_record-650.jpg
Click the meter edges and pull sideways.
We recommend the -6 value so you can go over by accident in the course of live recording without causing sound damage. Sound damage happens if a sound hits zero — goes all the way up. That can cause permanent damage and there is no recovery in post production.
What you have is a perfectly healthy recording. -6 is a target or goal, not a commandment or indictment of bad recording practices. I’m betting the passages sound fine.
Tracks may also be made taller by clicking on the bottom edge of the track and dragging down.
Thanks for all the feedback.
If you would still find horizontal lines on the waveform useful, feel free to reply and we’ll make a note of it.
I proposed something along these lines in the proposal for the new meters (that will be available in 2.1.0 when it is released)- see:
http://wiki.audacityteam.org/wiki/Proposal_Improvement_of_Meter_Toolbar_UI#Extension_to_this_proposal:_Graphic_indicator_of_optimum_recording_level_on_the_waveform_display.3F_.28Withdrawn.29
I actually withdrew that part of the proposal with the advent of the new meters - but if thought necessary I can revive it as a separate stand-alone proposal. Thoughts Gale?
Peter.
The Wiki Feature Requests page shows 18 votes for horizontal gridlines. There may be many use cases for them. I favour an option to turn them on so that you get as many grid lines as there are ticks on the vertical scale. I also think like James that there should be ability to add custom, movable horizontal grid lines. I would envisage this as a permanent thin horizontal bar above each track when the grid lines option was enabled.
You could drag this bar down into any track and drop it to add a custom grid line to all tracks. Drag from the permanent bar to add another custom grid line. Drag the custom line up or down to move the custom line. Drag it off the track to remove it. James sees doing this with sliders instead (presumably at the end of the track, I don’t know).
I have reinstated that proposal, spinning it off from the Meter Toolbars proposal. I transferred the above comments from Gale.
See: http://wiki.audacityteam.org/wiki/Proposal_Graphic_indicator_of_optimum_recording_level_on_the_waveform_display
Peter
