Hi and Low Pass Filters to reach ACX -60dB level
Koz and Trebor:
Thank you again for the insights. I’ll start working on the items listed.
I did find two vertical crackles or spikes in an audition I just did, and was able to edit them out. Thanks for the heads up on looking for those. They appeared like single lines in the audition track.
The microphone setup might be an issue. I did find a “card” /label hanging from the mic stand that I hadn’t noticed. It might have been bumping something to cause that noise. Not sure. I’m going to invest in a mic arm that I can bolt to the ceiling and bring down, so there is nothing to bump or jostle.
I’ll start work on the Microsoft to make sure all enhancement settings are off.
I’ll send another 20 sec test after that … and try to isolate the mic stand. I’m guessing you want a RAW .Wav file, right?
RE PURRING … Surrounding conditions include – basement room, quiet neighborhood (most of the time), no furnace on, no cat in the room, windows all blocked with sound deadeners, recording space surrounded by acoustic panels and on roof.
My laptop and monitor are in the space, but there are no computer or monitor fans and it is solid state, so they don’t appear to be making any noise. The light is LED and seems quiet.
It seems quiet to my ear, but… there must be something going on.
ok… on to the Microsoft settings!!
Thanks again for your time and patience.
Rode NT-1A
Did you get the whole doobly-doo set of accessories with the NT-1A?
That spidery thing on the back of the mic prevents vibrations and building noises from coming up the mic stand and interfering with the performance. The black tennis racket is the pop and blast filter. Most breath noises go straight ahead from your lips or down, so you can do well if you can put the microphone slightly above that.
This is my version of a setup.
In my case, the spidery shock mount is from a different maker than the microphone. Match the sizes and mounts. The mount is rubber bands and it’s not rocket surgery. You can make your own from the hardware store.
It doesn’t make any difference if the microphone is upside down or not, but it does count if the cable is too tight. A tight cable can transmit desk noise to the microphone. Leave a droopy cable.
I will admit to a little Hollywood in that studio shot. It looks grand, but if you think about where your face has to be to speak into the microphone, you would have to be on you knees at the desk. Adjust so you are comfortable and the microphone is in a good place and spacing. If you’re doing a book, you’ll be there for a while.
Do you know what’s causing them, or are you guessing? Tiny unstable recording problems can drive you nuts in the course of a book wherever they come from.
Nobody wrote you have to record your book on the computer.
That’s a Zoom H1n. That will record a voice track just fine.
Nobody is going to award me any voice production awards, but that clip will pass ACX Technical Standards.
Without problems sound editing takes five times the length of the show. That seems silly until you start to count the actual time and effort. Two shows of time is soaked up listening to the recording to making sure you know where all the errors are, and listening to the whole thing again to make sure you got them all. That leaves three shows of time to do the actual cutting, correcting, patching, filtering, and smoothing. It can go much longer.
Then mastering and then making sure you have the right silence (Room Tone) on both ends of the chapter.
Then on to the next chapter which has to match this one. The first and last book chapters have to match. They check for this stuff.
Gah I wish I was at 3:1
Even after three months of recording, practice, videos, forums, and time-saving macros, and processing techniques, I am still taking so much time to process after I record.
30 pages (Final Length 38:16)
Raw - 60 minutes for the first-pass record (Dog Clicker and some Punch and Roll)
SAVE WAV
Text Complete (ReDos, Retakes, MisReads Repaired) - 60 minutes (listen and parse, rerecord and splice)
SAVE WAV
Gasp and Spacing - 90 minutes (Commas, Periods, Sections, Punch-Pasting Room Noise over Gasps, clicking long pauses to uniform lengths.)
SAVE WAV
Mastering, Encoding - 10 minutes (THANKS KOZ!!!) (Roll Off, RMSNorm, LImit, ACX-Check) PASS!
SAVE WAV & MP3
Relisten for final - 38minutes
Upload
So I run about 8:1 (BLEGH!!!)
That’s the comeback for people who want to dash off their audiobook. "How bad could this possibly be?
Not bad at all if you’re a professional announcer in a formal sound studio and you’re not the one that’s cutting it.
There is a video performer I like who will come right out and say, “Don’t call attention to the features of that building because then I’ll have to shoot cut-aways and the edit will take forever.”
Words to live by.
Koz:
Correct. I got the, as you put it “doobly-doo” NT1-A … Anniversary set, https://forum.audacityteam.org/download/file.php?id=26436
Similar to folks in previous posts, I’m currently spending a frustrating amount of time listening to, relistening to, rerecording, editing, cutting out noise, etc. I’m guessing I’m well above the 5:1 ratio, but getting better each time.
I’d love to eliminate more noise, so I can reduce that phase of the process.
Reality is, my biggest challenge is learning to do it right the first time, and streamline the punch and roll.
Practice, practice.
Because I haven’t been Suzy Sunshine for at least ten minutes, that’s actually a problem. The first and last chapters of the book have to match.
It’s not unusual for New Users to get to the last chapter as a seasoned professional and go back to the first chapter (which they recorded as a green beginner) and are horrified. And record several chapters again.
There is one New User phenomenon. It’s possible to be too picky. If you can hear things nobody else can, maybe you don’t need to worry about them.
This isn’t the only place to get good tips. ACX has postings and useful instructions and any minute I’m going to find them and post a collection. They changed the free test, for one example.
We’re been known to recommend something like that. How’s that working for you? The clicker produces a blue spike that easy to see in post.
When was the last time you posted a sound test? Have you ever?
Sometimes we can suggest microphone placement changes and peel off some of the post production corrections, edits, and work. Yes, if you read the wrong words, we can’t help you. You’re stuck there.
Koz:
You asked: “When was the last time you posted a sound test? Have you ever?”
I’m guessing you’re asking about posting it on the Audacity Forum … If so, the last (second) sound test I did was 1:47 p.m. on March 12, page 1 of this string. But, I’ve made several adjustments… new microphone stand placement, turned off Microsoft enhancements, turned off secondary speakers, etc.
Maybe another test is warranted …?
Also, yes, I’ve been watching several ACX University videos and other audiobook tutorials a day… some of it might be seeping in.
Hope to get to some voice lessons in the near future … presently delayed by the Wuhan Flu.
Meanwhile, several more ACX auditions, but no contracts yet… It’s coming.
Were they failures? What was the failure? Post the ACX response.
Make a forum test. If you’re doing something obvious wrong we may be able to correct it.
Koa
