Help
hi,
frustrated at just trying to record my voice on my comp
so many choices…
3 sockets at back … pink green blue
Im guessing pink is best option
Ive got a digital mike logic 3 so dont think any problem there
with … microphone realtec hi def audi … I am getting at least some audio result
but its a very low recording
thanks for any help or advice
I also want to get on google doc and try out the VOICE TYPING in there… but so far
dont seem to have a mic signal in there !
Pink is correct for the microphone.
I don’t know anything about that mic but if it has the proper 3.5mm plug to plug-into the pink mic input it should work. (A digital mic would have a USB connector.)
Windows has [u]Microphone Boost[/u].
There are some Windows [u]Microphone Security[/u] settings.
And there are [u]Windows “Enhancements”[/u] which more often degrade the sound rather than enhance it.
