HELP!
Using W 10 ( :unamused: ) and Audacity new 2.3.3
I have attempted opening up my EVP/Audio files in new version and older version replaced. Cannot find older versions to return to it. I cannot go to a file on my portable hard drive, right click, then select “open with” as its not there as an option for me to try opening with NEW Audacity!?!?!?!?
Also, when I go into Audacity and try loading an audio clip, it makes ALL the EVP/AUDIO files download in their own brackets instead of connected as ONE continuous stream!!! This is impacting my ability to get evidence review process completed and to my clients holding up progress.
ANY tips?!
So, basically the problem is the “open with” menu from your Windows 10.
Did you try to “select another application” and guide the menu to the Audacity executable?
You may also open Audacity first and use it’s “File” menu.
Sorry if I misunderstood your problem; it should be easy to solve.
