Hello i am Federico, in Audacity I can select “Record Input” as Wave, Microphone, Stereo Mix, etc., but how I can select Wave and Microphone simultaneously?
Thanks Federico
[Advert removed by moderator]
Audacity can only record from one device at a time.
If “Stereo Mix” works on your machine, and it is possible to listen to the microphone input by enabling “listen to this device” in the Windows Sound Control Panel, then recording from Stereo Mix should record everything that plays through the sound card.
Generally it is better to record one thing at a time, for example by “overdubbing”. See: http://manual.audacityteam.org/man/tutorial_recording_multi_track_overdubs.html
