If possible I NEED TO SPEAK TO SOMEONE WHO CAN WALK ME THROUGH THIS. I am frustrated and need to get my assignments turned in ASAP
Audacity doesn’t have live chat or telephone support. However, we do OK on the forum. What’s the specific problem? The most information you can tell us about your system the better.
http://www.kozco.com/tech/audacity/Documents/PostingQuestions3.pdf
People do get burned with promising insanely complicated productions with a program they’ve never used before. Audio (and video) productions are not simple.
Audacity is free. The support team are volunteers. We don’t have the resources to offer one to one telephone / e-mail / Skype help.
You are welcome to post support questions here on the forum. Please ensure that you provide sufficient information about your system, what you are trying to do, and what the problem is, for us to be able to help you.
If you are completely new to Audacity, a good place to start is the Getting Started section in the manual: http://manual.audacityteam.org/o/quick_help.html
The full manual is also available in the Audacity “Help” menu.
