Help with using Shure beta57A
I’m using a Shure beta 57A, but audacity does not pick up any sound when the mic is connected.
Is there a way to fix this and to make the two compatible?
It’s probably not so much Audacity as your computer. We need more details. Exactly what computer and OS are you using, what kind of cable are you using to connect the microphone to your computer, and where on the computer are you plugging it in?
  • Bill
Sorry for the lack details!
I got it to work after some tweaking on my computer.
Thanks though :smiley:
