Help with installing 2.0.2 on Marndriva 2010.2
I read the readme which states that wxWidgets must be installed for this version. I downloaded and installed it from source with no issues, wxWidgets-2.9.4. The output of ./configure for Audacity is below:
[chris@localhost audacity-src-2.0.2]$ ./configure
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for C compiler vendor... gnu
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking how to run the C++ preprocessor... g++ -E
checking for a BSD-compatible install... /usr/bin/install -c
checking for pkg-config... yes
checking for a sed that does not truncate output... /usr/local/bin/sed
checking whether the linker accepts the -rdynamic flag... yes
checking for an ANSI C-conforming const... yes
checking for grep that handles long lines and -e... /usr/local/bin/grep
checking for egrep... /usr/local/bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for size_t... yes
checking for alloca.h... yes
checking CFLAGS for strict prototypes... -Wstrict-prototypes
checking wall_flags for maximum warnings... -Wall
checking whether the C++ compiler accepts the  -Wall flag... yes
checking whether the C++ preprocessor accepts the  -Wall flag... yes
checking for simple visibility declarations... yes
checking for wx-config... /usr/local/bin/wx-config
configure: Checking that the chosen version of wxWidgets is 2.8.x
configure: error: Unable to locate a suitable configuration of wxWidgets v2.8.x or higher.
The currently available configurations are listed below.  If necessary, either
install the package for your distribution or download the latest version of
wxWidgets
from http://wxwidgets.org.
    Default config is gtk2-unicode-2.9
  Default config will be used for output
Can someone point me in the right direction as to what I’m doing wrong.
Thanks
Chris
WxWidgets 2.9 is not currently supported. Audacity uses WxWidhets 2.8 (preferably 2.8.12).
Probably the easiest way to get a working Audacity installation is to install Audacity with your package manager.
I’ve already got a working version, 1.3.12-Beta running fine but wanted to upgrade. Running urpmi audacity just tells me I’ve got that package already installed. Guess my only other option is to build the rpm.
Dummy me!!! Forgot all about rpmfind.net. Found the 2.0.0 Mandriva 2010.2 version and installed with no problem. Don’t think the Mandriva 2011 version of 2.0.2 would install. At least I’m better off than I was before.
One last question before I close this thread as solved, do I still need wxWidgets installed?
You only need wxWidgets installed for building Audacity from the source code.
