OK. It’s daytime in Los Angeles.
One of the questions that comes up with the Mastering Macro is when to do edits. Your show should have all the fluffs, mistakes, bad words, tongue-ticks and other noises removed before you get here. Mastering should be the last thing that happens (except possibly noise reduction after) before you export your Edit Master WAV file, and then the submitted MP3.
As I think we already posted, the WAV and the MP3 file should sound identical. There is no bad MP3 version.
The Mastering Macro is a text file. A plain word list of computer instructions.
That can be confusing for everyone. The computer is now confused because it can’t tell if you wrote a letter to your mum, or wrote a program. Can you get it to settle in as a file on your desktop or wherever your computer downloads or imports stuff?
You’re on Windows, right? Windows might try to “help you” by hiding the dot-t x t at the end of the name. Do you have a “Get Info” tool in Windows? That should show you the “real” filename. Alternately, you can force Windows to just show you filename extensions all the time. That’s how I did it.
In Audacity.
Tools > Macro Manager > Import.
Locate the text file.
Import it.
Close.
Select the timeline or show. Tools > Apply Macro > Audiobook-Mastering-Macro.
There is no “do it.” it runs by itself.
The macro was designed so you can’t hear it working except the show may get a little louder. It doesn’t change the character or quality of the sound.
Apply ACX-Check and the show should magically conform to ACX Peak and RMS (Loudness).
If you recorded in a quiet, echo-free room, you may be done.
If you have a little background noise or Room Tone, you might want to apply Noise Reduction of the Beast. 6, 6, 6. You should pass ACX noise by -65dB or quieter. -62dB or -63dB does pass (the limit is -60dB) but if you do anything wrong anywhere, the show or chapter will fail. The conversion to MP3, for example, will shuffle sound volumes a little.
