I am trying to cut out all back ground noise from a 911 call please help, I tried to upload but its to large.
If you cannot understand what is being said in the call, odds are neither Audacity nor AI will make it comprehensible, (that only happens in the movies).
Stop giving away our secrets.
No number in America suggests crisis and drama more than 911, the countrywide emergency help number. In some states, access to 911 recordings may be limited, but in others, you can obtain the calls as a matter of public record. One of the main reasons to need a 911 call recording is for its use as evidence in related court actions.
Audacity can’t be used for Surveillance, Law Enforcement, or Conflict Resolution.
Thank you for your reply.
Thank you I am so sorry if I did something wrong on here not my intentions at all. I should have ask if someone could send me to a company or someone who does this,
Thank you again
This forum is for help with Audacity. We do not offer recommendations for commercial services, and advertising is prohibited.
If you post a short sample of the audio you are trying to fix, I expect that one of the experts here will be able to tell you if significant improvement is possible. Post a short section (about 6 seconds) in WAV format.
