Hi. My apologies if this has been asked before but I couldn’t find any thread that solved my problem. I have put all the correct setting to record the audio coming from my headphones but when I record and export it, I hear nothing, only the sound coming from my microphone. I have tried all the servers and different settings and nothing worked. Updated Audacity, reset my pc, still nothing. Also my drivers are fine. Does anyone know what the problem might be?
Use WASAPI loopback as your recording device.
