Help me My 3.7.5 versions doen´t open
I just update for the 3.7.4 version and now it doens´t open. Keep showing me a bug, and don sent report.
How can I going back to download old versions?
I have win 10.
Pls need help
Tks
Rename*/delete the Audacity config file … Resetting Audacity | Audacity Support
[ * renaming gives you the option of reverting ]
Older versions are here.
But, DO rename or delete the configuration file because it will try to keep the existing settings and that file might be fouled-up.
I don’t know if “report” ever works or if anybody ever sees it… Maybe, maybe not…
Thanks..
I deleted the Audacity, and then put thr 3.7.2 Version.. And it Runs!!
tkns a lot
