Help file proof reading
Is there a place to report issues with the Help file? Think I found a need for minor correction.
-Ed
Sure, you can post here. Please give a link to the relevant document and quote exactly the bit that you think needs correcting.
See word circled in Red… believe if should read `upper´.
-Ed
Thanks. I’ve corrected it in the alpha manual so it will be correct in the next release. (https://alphamanual.audacityteam.org/man/Sync-Locked_Track_Groups_-_Time_Stretching#Example-2:_Repeat)
Good catch - thanks edwinn
Peter
