Help debug this nyquist code
I am trying to build a Nyquist code that can convert text to tones. I added an interface for tone duration and waveform type (drop down list). The code doesn’t work and this is the bug output. Please help me fix this
;nyquist plug-in
;version 4
;type generate
;name "Text to Tones"
;action "Encoding text into tones..."
;info "Encodes text into sequential tones, where each character corresponds to a specific pitch."
;control input "Words to encode" string "" "Paste the text here"
;control wave-type "Waveform Type" choice "Sine" "Square" "Sawtooth" "Square No Alias" "Triangle"
;control tone-dur "Tone Duration (seconds)" real "0.1" 0.01 10.0
(setf input-stream (make-string-input-stream input))
(defun tone (freq)
  "Generates a tone at a given frequency (in Hz) and duration based on the selected waveform type."
  (case (char-upcase wave-type)
    ("SINE" (osc freq tone-dur))
    ("SQUARE" (osc freq tone-dur *table-square*))
    ("SAWTOOTH" (osc freq tone-dur *table-sawtooth*))
    ("SQUARE NO ALIAS" (osc freq tone-dur *table-square-no-alias*))
    ("TRIANGLE" (osc freq tone-dur *table-triangle*))))
; Initialize output
(let ((out (s-rest 0)))
  (do* ((ch (read-char input-stream) (read-char input-stream))
        (i 0 (1+ i)))
      ((not ch))  ; Stop when end of input is reached
    (setf ch (char-upcase ch))  ; Convert to uppercase
    (setf note
      (case ch
        (#\A (tone 1))
        (#\B (tone 2))
        (#\J (tone 3))
        (#\D (tone 4))
        (#\E (tone 5))
        (#\W (tone 6))
        (#\Z (tone 7))
        (#\H (tone 8))
        (#\U (tone 9))
        (#\Y (tone 10))
        (#\K (tone 20))
        (#\L (tone 30))
        (#\M (tone 40))
        (#\N (tone 50))
        (#\S (tone 60))
        (#\I (tone 70))
        (#\F (tone 80))
        (#\! (tone 90))
        (#\Q (tone 100))
        (#\R (tone 200))
        (#\O (tone 300))
        (#\T (tone 400))
        (#\C (tone 500))
        (#\J (tone 600))
        (#\P (tone 700))
        (#\? (tone 800))
        (#\V (tone 900))
        (#\G (tone 1000))
        (#\space (s-rest tone-dur))  ; Silence for spaces
        (t nil)))  ; Ignore unsupported characters
    (if note
        (setf out
          (sim out
               (at (* i tone-dur) (cue note))))))  ; Append each tone sequentially
  out)  ; Return the final audio output
[Moderator: Code tags added for readability]
The choice widget returns an integer.
