I have about 2000 files that I want to use with the NotchFilter.
I was able to create a chain with the NotchFilter parameters I require but I can’t quite see how the files themselves are loaded and saved.
I tried ApplyChain and select the root of the directory structure where my files reside. I don’t see how the files are selected, nothing appeared when I tried entering *.aiff as the file name. The files are actually in subdirectories below the root so it is pretty obvious that no searching for files is being done. I can select files if I enter the various subdirectories, but that seems to defeat the whole purpose of using subdirectories.
I also looked in the chain commands for an option to save an AIFF file. Although there are several ExportXXXX commands none of them are directly applicable and apparently I can’t edit them to create a new chain command. How optional uncompressed formats specificed in a chain?
I just need a simple chain that will perform 3 steps on all the files in my tree:
- Load file (24/48 AIFF)
- Apply Notch filter
- Save file (24/48 AIFF)
