Please see previous post. I received something which I already tried. Tried again and nothing. I CAN’T close any of the running Audacity programs. The little multicolored just keeps revolving. Need specific instructions if possible thanx
Any of the running Audacity programs? What do you have running?
Apple (upper left) > Force Quit.
Then restart your Mac.
If the Mac is permanently hung, press and hold the power button for ten seconds. Count to ten and then start normally.
Did you follow the Audacity install instructions? Audacity will not work right unless you drag the program folder into Applications.
