Hearing What You're Recording
Hi,
I’ve had this program for less than 24 hours and am trying to record voicemails from my phone to save them. I have the recording part down but cannot hear what is being recorded while I’m recording/playing the voicemail. I’ve played around with the ‘output’ controls and still cannot figure it out. Any suggestions/help is much appreciated!
-R
How are you doing that?
What sort of phone and how is it connected to the computer?
Its a blackberry. I believe its called the auxiliary output/jack - the one you’ll plug headphones in with. Except a cord with 2 male ends, say for if you were to plug your ipod into your car with the auxiliary jack. The phone to the microphone jack on the computer. I think that explains it…make sense?
Look in the Windows Sound Control Panel and ensure that “Listen to this device” is enabled for the recording input that you are using.
