So, I have a raw TrueHD audio track from a BluRay in a thd file, also attempted via a mkv file with just the TrueHD stream. The import takes a bit, then fails and says “Audacity did not recognize the type of the file…”. This is the demuxed thd data, not touched by anything else. Plays just fine on a player like xbmc. Now, I downloaded a sample thd file to see if TrueHD is actually supported at all. This is a channel test file, and, it’s in a mkv file, and, it does successfully import, all 8 tracks. So, it can do so.
My question is… Why would a much larger (could that be it?) thd file from a Bluray not import? The audio is not protected. It plays just fine in other software. MediaInfo has it looking the same as the sample file, I don’t see any difference, and both codecs are the same, A_TRUEHD (FourCC). Demuxed via mkvtoolnix. The thd file is a little over 4GB, so, uncompressed, it’s likely pretty large. Wondering if it’s more a size limit perhaps? How could I figure out the real issue?
Checking the log file, for the success sample file, it says:
13:12:20: File name is /Users/sfatula/Downloads/7.1Ch Dolby TrueHD - Speaker Mapping Test File.mkv
13:12:20: Mime type is *
13:12:20: Opening with libav
13:12:20: Open(/Users/sfatula/Downloads/7.1Ch Dolby TrueHD - Speaker Mapping Test File.mkv) succeeded
For the failed file, it says:
13:14:07: File name is /Users/sfatula/Documents/SomeMovie.mkv
13:14:07: Mime type is *
13:14:07: Opening with libav
13:14:23: Error: FFmpeg: avformat_find_stream_info() failed for file /Users/sfatula/Downloads/San Andreas 3D-TAB 1080p.mkv
Using Audacity 2.1.1, Mac OSX 10.10.5.
I ran a ffprobe of the file, using Macports ffmpeg version 2.8, and got this:
[STREAM]
index=0
codec_name=truehd
codec_long_name=TrueHD
profile=unknown
codec_type=audio
codec_time_base=1/48000
codec_tag_string=[0][0][0][0]
codec_tag=0x0000
sample_fmt=s32
sample_rate=48000
channels=8
channel_layout=7.1
bits_per_sample=0
id=N/A
r_frame_rate=0/0
avg_frame_rate=0/0
time_base=651/31250000
start_pts=96102
start_time=2.001997
duration_ts=N/A
duration=N/A
bit_rate=N/A
max_bit_rate=N/A
bits_per_raw_sample=24
nb_frames=N/A
nb_read_frames=N/A
nb_read_packets=N/A
DISPOSITION:default=1
DISPOSITION:dub=0
DISPOSITION:original=0
DISPOSITION:comment=0
DISPOSITION:lyrics=0
DISPOSITION:karaoke=0
DISPOSITION:forced=0
DISPOSITION:hearing_impaired=0
DISPOSITION:visual_impaired=0
DISPOSITION:clean_effects=0
DISPOSITION:attached_pic=0
TAG:language=eng
TAG:title=English (TrueHD 7.1 48KHz)
TAG:BPS=5239411
TAG:BPS-eng=5239411
TAG:DURATION=01:54:28.612005696
TAG:DURATION-eng=01:54:28.612005696
TAG:NUMBER_OF_FRAMES=8242335
TAG:NUMBER_OF_FRAMES-eng=8242335
TAG:NUMBER_OF_BYTES=4498435750
TAG:NUMBER_OF_BYTES-eng=4498435750
TAG:_STATISTICS_WRITING_APP=mkvmerge v8.5.1 ('Where you lead I will follow') 64bit
TAG:_STATISTICS_WRITING_APP-eng=mkvmerge v8.5.1 ('Where you lead I will follow') 64bit
TAG:_STATISTICS_WRITING_DATE_UTC=2015-10-29 05:58:41
TAG:_STATISTICS_WRITING_DATE_UTC-eng=2015-10-29 05:58:41
TAG:_STATISTICS_TAGS=BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
TAG:_STATISTICS_TAGS-eng=BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
[/STREAM]
[FORMAT]
filename= SomeMovie.mkv
nb_streams=1
nb_programs=0
format_name=matroska,webm
format_long_name=Matroska / WebM
start_time=2.001997
duration=6868.612005
size=4556349747
bit_rate=5306865
probe_score=100
TAG:title= SomeMovie
TAG:encoder=libebml v1.3.3 + libmatroska v1.4.4
TAG:creation_time=2015-10-29 05:58:41
[/FORMAT]
