Hi. I’m new here and seem to be a bit lost.
I have purchased the cassette to MP3 Converter and have installed the software from the disk included.The version of Audacity is 2.0.2 and I downloaded from the .exe file. I have Windows Vista. I have a second computer with Windows XP. That computer isn’t online so I transfered the Audacity folder to it from the Vista machine. I am having the same problem on each.
The problem I’m having is in downloading to the computer from the Tape to MP3 player. When I start the player and then press the red “Record” button I get a flat line in the progress bar. The unit is running correctly as I listen in via earphones.
On the XP machine I did get it to record once. I don’t think I did anything different to the other attempts, but I’m assuming I must have.
I’d really appreciate some help with this please.
Thanks, Bill.
