Hello!
I’m having a problem exporting the audio. This message shows. What does it mean?
Thanks!
Yetta
Hello!
Thanks!
Yetta
A question mark is not allowed in a filename (at least on Windows).
[Moderator Edit: Added code tags to preserve special characters]
In addition to DVDdoug’s comment, you may hit problems saving to “OneDrive” as it is a special kind of cloud-based directory.
Thank you sooo much!
It should be noted that a comma in a filename will cause problems, even though most “forbidden” lists leave it off. It is best to not put any commas in filename, else the operating system could think they are two filenames separated by a comma.
Thank you, Wrecks0!
