Splitting stems works great with OpenVino in Audacity 3.5.1, but only once. When trying to split a second track, there will be added a strange artifact to each part which sounds like a loud crackle of a constant frequency without splitting properly.
Restarting Audacity doesn’t solve the problem. Neither does disabling/ enabling OpenVino. The only thing that works is reinstalling OpenVino, but again, just for one track. I assume that this is not the intention to work with OpenVino.
A workaround which is a bit less irritating than uninstalling / re-installing the plugins is to delete this folder before running the effect each time: %appdata%\audacity\openvino-model-cache (just copy & paste that into Windows explorer).
Could you let me know which version of Windows you’re using? I’m still trying to understand which specific configurations are causing this issue.
Would you mind sharing what language of Windows installation you’re using? I don’t know yet if it’s related, but a couple of users who have experienced this issue have been using the German version of Windows 10/11.
