I see the basic hardware requirements, but would like more specifics. (2 GB of RAM, 1 GHz processor). I have used and appreciated Audacity with Windows 10 on a laptop for years without knowing (or wanting to know what the computer specs were. That computer finally went belly-up and I’m shopping for a laptop or tablet hopefully in the $200+$300 range that can work well with Audacity. Was gifted a Chromebook 3 that I use for other computer needs, so plan to dedicate the new laptop just for Audacity and perhaps Photostage slide creator.
I see where Audacity recommends “much higher” RAM/processor capacity if recordings are to be “lengthy multi-track projects” and this is where I would like more specifics. I usually use 4 to 6 tracks around 4 minutes long before calling it good and exporting. (Samples on youtube under “Myer Hollow” used Audacity and Photostage.)
Any help with my shopping for the hardware would be much appreciated! Have considered the HP Stream 11.6 w/Windows, but again, not sure if it would easily handle these programs.
Alan
