I have a MacBook Pro Sierra / version 12.12.6.
Audicity 2.3.0
Everytime I import wave files 44K / 32 bit from Logic 8, everything sounds great. I can edit and master…etc. But after I close Audacity and shutdown my computer, then start up again the next day the wave files-song sounds gurgly and almost distorted.
I tested and tried many different wave files but it’s always the same experience.
Any ideas?
Thank you,
Lynn
Do you have Finder set to show you file name extensions? Finder > Preferences > [X] Show all Extensions…
If you have a WAV file, does it say something-something.wav, or just something-something?
You keep working on WAV files but your description of the problem is the poster child for damaged compressed file types.
Is the work damaged when played in QuickTime Player, iTunes or other player? Different computer?
Where did the work come from? Are you performing live?
If you are getting the work from “Somewhere Else,” you may have WAV versions of already badly compressed sound. In that case,you’d be fine inside Audacity but any editing or production you do may become damaged, seemingly “too soon” from what you were expecting.
Cut a ten second portion of the damage and post it here.
I don’t record in Audacity. I import wave files to edit and master. Everything sounds great and there’s no problem until I shutdown my computer then restart at another time.
Thanks for the detailed response.
Finder is set to show you file name extensions
Wave files say “something.wave”
There’s no compression, no EQ added to it. It’s a plain file.
I attached 2 wave files. One is non gurgly and one that is gurgly.
This non-gurgly wave sounds fine in I Tunes and Logic. But when I import it back into Audacity it has that gurgly sound.
The wave files are a name. audio.wave or drums.wave etc.
The recording is two guitars with two different mics. I only sent one file, not both. The point is to hear the gurgly sound.
The point is to fix the gurgly sound. Changing the conditions between “Before” and “After” test clips isn’t helpful, particularly as you said you didn’t. The two clips are different and it has nothing to do with the second guitar. Somehow, the single guitar track went from mono (one track) to stereo (two tracks) and it would be good to know the step that created that change.
We have to build your system in our imaginations to diagnose problems. It’s difficult to hit a moving target.
