Group needs a fix
The Group feature, which replaced Sync-Lock Tracks, feels a bit cumbersome to use.
To enable it, we have to manually select all clips and splits within a track. This is not practical, and it becomes even more tedious when working with long tracks containing many splits.
Additionally, enabling the feature requires navigating to the three-dot menu on the right side of one of the tracks. Again, for large projects with long tracks, this process is time-consuming and inefficient. A right-click context menu would be a much better solution.
It would also be helpful to have a drag-selection feature that allows users to quickly select and group multiple clips.
This topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
