Hi forum.
Am working on MAC (latest OSX) and Audacity 2.0.4.
I’m trying to turn a 75 year old mono sample into stereo! Harder than it sounds!
Have duplicated the clip, adjusted one of the files by 2ms and thats where I run into trouble!
The drop menu under each of the 2 tracks (on the left hand side of the screen) is partly greyed out!!!
Mono
Left Channel
Right Channel
Make Stereo
All the above are greyed out! No idea how “un grey” them!
If there is an easier way to convert mono to stereo then I’d be delighted to know!
Appreciate your feedback thanks
A.N
Hi Steve, thank you for your very prompt response.
I’ve double checked the functions that you mentioned in your post. No luck I’m afraid!
Before I install and run the Pseudo Stereo plugin I need to convert (as you have rightfully suggested) my Mono track to a 2 channel track before using the effect.
The plugin says: To do so, click above the Mute and Solo buttons in the Track Control Panel, choose Edit > Duplicate then click on the name of the upper track and select “Make Stereo Track” from the drop-down menu.
Obviously this is easy - plain english! Still the “Make stereo” option is greyed out!
Am I missing something in my preferences?
I still can’t begin to figure out whats going on here!
thanks
A.N
Hi Steve
I can assure they’re not in stereo!
one channel is just white noise hence the level reading.
playing through my monitors - is definitely 1 channel only.
As far as Audacity is concerned, it is a “Stereo” track. Audacity is only interested in the number of channels, not what it sounds like Those tracks have 2 channels.
What you will need to do is to split each of those tracks (Track drop down menu > Split Stereo to Mono") and delete the “noise” tracks (click on the in the top left corner of the track). You will then be able to join the remaining mono tracks.
