Hi all. This is my first post on the Audacity Forum. I’m running v2.1.1 on macOS Mojave v10.14.6.
I hope that someone can check out the attached sample and let me know if there’s anything I can do to salvage this old recording. I’m having no luck using trial and error settings on the Graphic EQ and I’m running out of options… and patience.
I have an equalizer setting that helps a tiny bit. I’ll figure how to send it over any minute now. You have to use Filter Curve. Graphic Eq doesn’t have enough range.
Thanks, Steve and Koz.
I haven’t used Filter Curve so I tried fiddling around with it. The bad news is that I couldn’t get anywhere near the quality I was hoping for. The good news is that I learned a new tool. I guess that’s worth something.
Anyway, I appreciate the support. Case closed.
Stay safe!
-Alan
