Good day to all, good poops and caffiene to you
I’m having a problem adding different plug in effects to my audacity to program, I identified my first issue which was recognizing the dll file type as a supported format but my problem now is when attempting to enable the effects, I get a error message indicating unable to register effect to audacity library… if someone has some advice it would be much appreciated. Thank you in advance
The only VST plugins compatible with Audacity are 32-bit VST2 type.
