Getting Started
My goal is to transfer my PLs to my laptop.
I have a turntable, a Behringer UCA222, and an HP laptop using windows 10.
I have connected everything as I believe it should be. Started turntable and clicked on input level.I can hear music weakly via earphone plugged into the B222. Audacity gives blasts of sound followed by long spans of silence.The blasts do not seem to be coordinated with the music.
What to do?
Tell us about your turntable/analog setup… If you have a “traditional” turntable you need a phono preamp (or the UFO222).
If you have a stereo system that works with the turntable it has a preamp built-in and you can connect tape-out or the headphone output to the UCA222.
Did you select the USB device as your [u]Recording Device[/u]? (You may still that weak sound.)
All good stuff. Thanks.
